Fast hitch prong measurements
Mark Johnson
05-07-2007 21:03:55
Can someone trace or take a picture of the prongs for a SuperC fast hitch prong with measurements at the tip back to the notch and height?I need to see what i can do to get an adapter to work that i got.
georgeky
05-08-2007 08:29:01
 Re: Fast hitch prong measurements in reply to Mark Johnson, 05-07-2007 21:03:55
At The back side of notch the prong should be 2 1/4 inches instead of 1 1/4 I hit the wrong key.
georgeky
05-08-2007 08:22:48
This is common on after market prongs. It should 13 1/2 inches total from tip to the stops on the back end of prong. It can not be more than 3 high inches at the rear. It is 4 1/4 inches from tip to the front end of notch. at the back end of notch the prong itself is 1 1/4 inches high. At the end of the tapered part of prong it is 1 1/2 inches to the notch. The grinder is the right tool to fix this with. Just 1/8 of an inch somewhere will keep it from going all the way end. I usually take the grinder to the bottom edge and take a little at a time and try it. You will need to do some grinding no matter how you do this. If cut with a torch you will have to grind it smooth or it will cause trouble from now on.
PUTTER
05-08-2007 06:19:40
Mark, Have you tried putting a little pressure on it. My 340 draw bar sometime requires me to back up to a tree to get it to fit in all the way but will come right out after I use it a while. I keep my hitch pockets greased but that also makes them attract dirt. If I were only lacking an inch like You say you are I'd see if a sledge would put them home also look for dirt buildup in the pockets, They are supposed to fit tight. PUTTER
georgeky
05-07-2007 21:09:54
If it is one for the larger hitch on 300/350/400 and so on just shave a half inch off the bottom and it will work fine.If not let me know and I will go to the barn and do a little measuring.
Mark Johnson
05-07-2007 22:51:18
 Re: Fast hitch prong measurements in reply to georgeky, 05-07-2007 21:09:54
This is for the smaller fast hitch,if you could give me some accurate measurements i would appreciate it.It was made from an company to "fit" the SuperC and lacks about 1 in. from sliding all the way in and the catch dropping in.Thanks
Wardner
05-07-2007 23:05:15
 Re: Fast hitch prong measurements in reply to Mark Johnson, 05-07-2007 22:51:18
One would have to think that everything fit when it was new. Maybe you need to check for straightness, rust, or dirt.
If everything checks out OK, I would use some modeling clay or window putty to find the point of contact. At that point, get out the grinder or file.
Mark Johnson
05-07-2007 23:41:19
 Re: Fast hitch prong measurements in reply to Wardner, 05-07-2007 23:05:15
These things are thick a grinder will hardly touch it.I would like some measurements so i can use a acetylene torch to cut off needed amount.This is an aftermarket adap and as i have found out they dont make them perfectly rite.
El Toro
05-08-2007 04:06:33
 Re: Fast hitch prong measurements in reply to Mark Johnson, 05-07-2007 23:41:19
It may be better to cut or have the metal cut using a plasma cutter. Hal
