404 hydraulic?
TWL
05-08-2007 13:08:53
My neighbor has just bought a 404 and wants to check the hydraulic oil.Would any of you know if it has a dip stick or where to check the level.Thank you for any help.
HughB
05-08-2007 13:32:01
 Re: 404 hydraulic? in reply to TWL, 05-08-2007 13:08:53
Look on top of the transmission directly behind the gear shift lever. There is a plug that you use to both fill and check the fluid. It should be up to the level of the plug. A good investment would be to order both the operators manual and the shop manual from "yesterdays tractor co". A lot of good info in them both.
