Put the Red Power in the field.
JTinNJ
05-08-2007 15:41:27
I hooked up the chisel plow to the 966 yesterday.Went into a field that had not been worked at all for at least 15 years. Deep sod and clay. Made that 414 talk.She is old and faded,but,she sounds great.Pulled the 7 tooth plow with no trouble at all.
GeneMO
05-08-2007 19:43:36
 Re: Put the Red Power in the field. in reply to JTinNJ, 05-08-2007 15:41:27
We pulled a 7 thooth with our 766. It was all it wanted, but we used it for years. Never pulled it in any sod though. That 9 should have played with it, right?
Gene
JTinNJ
05-08-2007 21:39:24
 Re: Put the Red Power in the field. in reply to GeneMO, 05-08-2007 19:43:36
Last year I pulled the plow with a White 2-70. It was more then the White wanted.I got this 966 in Jan. What a difference.It would pull more then the 7 teeth. But,you can't use what you don't have. Next is the 14 ft disc.
georgeky
05-08-2007 21:55:08
 Re: Put the Red Power in the field. in reply to JTinNJ, 05-08-2007 21:39:24
Nothing like Red Power.
