PTO Shields
GordoSd
05-09-2007 07:23:38
I have several PTO shields for the Farmalls. They are different lengths. 13 Inches, 6.5 Inches and 10 Inches. They have the correct bolt spacing and flanges. Anyone have info on which letter series gets which one? Want to put the correct ones on the H, the SH, and the SMTA. Looking at old manuals it looks like they all might use the long , 13 inch model.
Gordo
TractormanNC
05-09-2007 17:37:31
 Re: PTO Shields in reply to GordoSd, 05-09-2007 07:23:38
Anybody got one for a 656 or 666 they would part with?
Nat 2
05-09-2007 08:50:12
The H and SH will use the longest, 13", shield.
That 10" shield fits a regular M or Super M. It's shorter because the distance from the axle to the drawbar hole is the same between an H and M, and the M's rear housing is larger. There's less PTO protruding from an M than an H.
The SMTA will use the shortest, 6" shield. Rather than bolt over the entire PTO, it bolts to the rear of the IPTO unit.
Since you've only got 1 13" shield, you'll have to use the 10" on one of the Hs. Better than nothing, at least.
georgeky
05-09-2007 07:38:25
The H and Super H use the same one a long one it will be tapered down on the end that fits tractor. The one for an SMTA is only 6 1/2 inches long.
Allan In NE
05-09-2007 07:40:26
 Re: PTO Shields in reply to georgeky, 05-09-2007 07:38:25
I always throw 'em under the work bench too. Those are the most "unhandy" gizmos. :>)
Allan
williamf
05-09-2007 09:38:38
 Re: PTO Shields in reply to Allan In NE, 05-09-2007 07:40:26
I haven't had occasion to use the pto on my H, but I've been leaning toward getting a guard thinking it would be a good place to mount a tray or basket to carry my toolbox or a small cooler. Are they stout enough to carry fifteen or twenty pounds?
Wm
GordoSD
05-09-2007 11:26:24
 Re: PTO Shields in reply to williamf, 05-09-2007 09:38:38
WM, Yes they a stout enough for me to stand on so I guess a 20 lb toolbox wouldn't be a problem.
Iv'e seen a couple go at auction. One had a toolbox witht the implement dealer decal on it that sold it new (53) and the actioneers have seen enough of them that they say 'and it has the Parker tollbox'. I do have two of the 13.5 inch shields so I guess I have all my ducks in a row.
GordoSD
georgeky
05-09-2007 07:49:58
Allen I forgot to ask. How did that plowed ground work?
Allan In NE
05-09-2007 08:17:01
 Re: PTO Shields in reply to georgeky, 05-09-2007 07:49:58
Still too wet.
Hope to get out there tomorrow and knock it in the head. Darned grass and alfalfa is coming like crazy too.
If I don't hurry up and get it done, I'll have to plow it all over again. :>)
Allan
GordoSD
05-09-2007 11:39:19
 Plowing in reply to Allan In NE, 05-09-2007 08:17:01
Why not just spray them as you are planting?
Gordo
georgeky
05-09-2007 09:15:40
 Re: PTO Shields in reply to Allan In NE, 05-09-2007 08:17:01
Ground is in real shape here. I finished with the corn yesterday evening.
georgeky
05-09-2007 07:48:10
Me to. I have a whole stack of various shields on a shelf in the barn. OSHA wouldn't like it at all.
Mike CA
05-09-2007 11:24:01
 Re: PTO Shields in reply to georgeky, 05-09-2007 07:48:10
Got a 13" in good shape for an H you want to discard my way?
georgeky
05-09-2007 12:47:43
 Re: PTO Shields in reply to Mike CA, 05-09-2007 11:24:01
No Mike, I will keep them in case I quit using the tractors, I will put them back on. They are available new from OEM or from Brad at 1-888-824-0544. They run about 65 dollars.
Mike CA
05-09-2007 13:19:29
 Re: PTO Shields in reply to georgeky, 05-09-2007 12:47:43
Free from you would be cheaper :D
hehehe
no sweat. I'll get one eventually.
georgeky
05-09-2007 16:20:28
 Re: PTO Shields in reply to Mike CA, 05-09-2007 13:19:29
Then when I wanted one I would be out 65 bucks. It ain't eating nothing so I best keep it.
