Differential Oil Capacity
eryp
05-09-2007 15:35:22
I'm about to set out and change the oil in the diff. How much oil is in that thing? I just pulled out 6 gallons (looked like chocolate milk)but I'm not sure how much is actually supposed to go back in.
1942 Model M
Thanks for your help...
georgeky
05-09-2007 16:01:44
 Re: Differential Oil Capacity in reply to eryp, 05-09-2007 15:35:22
Yes fill tranny and rear end will fill as well.
georgeky
05-09-2007 16:00:34
Just a shade over 20 1/2 gallons.
eryp
05-09-2007 17:43:52
 Re: Differential Oil Capacity in reply to georgeky, 05-09-2007 16:00:34
That's Right. It took right about 13 gallons for the whole job.
Thanks again everybody for the replies.
It was nice to know that I could fill the tranny and diff at the same time - through the big hole on top of the diff and not through the tranny plug. Got out my trusty electric pump and emptied the 3 buckets in about 15 minutes.
Allan In NE
05-09-2007 17:38:27
Good Gawd George,
Don't think I could squeeze 20 gallons in my 966. :>)
Allan
georgeky
05-09-2007 18:44:04
 Re: Differential Oil Capacity in reply to Allan In NE, 05-09-2007 17:38:27
I don't know sometimes the wrong stuff just comes out. My 666 only holds 16 gallons. I should have said 13 gallons. I was going to really filler up wasn't I?
D Slater
05-09-2007 17:04:08
Thats going to be around 7 1/2 gallon to mutch.
eryp
05-09-2007 15:53:49
And one more question while I'm at it - do the tranny and the diff have the same oil compartment? I've drained the tranny fluid as well from the small plug that is underneath. So if I fill the tranny am I also filling the differential? Or are they separate compartments? How much goes in each?
As always, thanks for the replies...
