FAST HITCH problems...help
Clefus
05-09-2007 19:09:46
I was using a 3 btm -- 14 " fasthitch plow i recently got and I have 2 ???
1 : Someone replaced a share with one that protruded past the shin/landslide about an inch and also doesnt match up with the moldboard edge....it is a 4 bolt pattern 14 inch piece....the other two match up fine on both ends...I got a new Osmundson one at TSC and it also fits the same goofy way...
Where do I get a right one??
2: Same plow...plowing I caught something and tripped a plow back....what is the best way to re-set it.....i had a hair of a time jackin,beatin,pryin, sprayin.....
Thanks
georgeky
05-09-2007 19:20:07
 Re: FAST HITCH problems...help in reply to Clefus, 05-09-2007 19:09:46
The correct parts are available from IH. To reset plow just put it down on the ground and back up. If that doesnt work your trips need cleaning. I do not recommend putting oil on this as it will cause it to trip quite often. Some trips have grease fittings I would ignore those too. For genuine parts call Brad at 1-888-824-0544, he will ship them right to you.
Clefus
05-10-2007 03:19:15
 Re: FAST HITCH problems...help in reply to georgeky, 05-09-2007 19:20:07
THANKS Does the large bolt that the plow spins on need any certain torque?? I originally was going to remove it but didnt.... stuff was a little rusty and hard to move to reset it...i tried backing up as you said but it wouldnt go due to rust...
Where does one get info ( or manual) on setting up this plow and hitch adjustments....like draft control (the notched lever on left??? ) ?? ect...I put the tractors front and left wheel up on blocks and leveled up the plows as best as possible till the r hand fh arm screw was stopped....I have a op manual and pm manual for my 560 but may need one for the plow..
Thanks
georgeky
05-10-2007 06:54:15
 Re: FAST HITCH problems...help in reply to Clefus, 05-10-2007 03:19:15
To get the right manual you will need to know the model of your plow. Not sure, but you might get them here on YT at left click on tractor manuals and look. If not some are available from Binder Books and can be ordered on line. IH still has some as well. If you don't know your model no, post a picture of it here or in implement photo's and if not me, someone will know the model no. They built several different models of fast hitch plows. For plow parts you can call Brad at 1-888-824-0544. He has points,shares,shins,moldboards and even slats for them in stock in most cases. He may also have a manual.
