Carb for kero
41H
05-10-2007 07:48:20
Recently had carb for kero burning H rebuilt. It uses nothing but gas now. What would good initial settings be for the main and idle screws.
Don L C
05-10-2007 08:43:28
 Re: Carb for kero in reply to 41H, 05-10-2007 07:48:20
Hello 41 H, Idel, fuel needle is on front side....
Main jet(gas)adjuster is on the bottum....
Set the main jet screw 2 1/2 -- to 3 turns open...
Set the idel, fule screw 1 -- to 1 1/2 turns open...Then fine adjustment when warn..... .
Get you a Service manual fron Binder books....503 684-2024...Good luck Don...
