Belt Pully gear box, no idea what this is off of?
Andrew Z
05-10-2007 09:23:01
I have a belt pully that is driven off of a 1 1/8" pto. the numbers on it are (3 9 51) which I persume is the date of cast, but if it were IH whould it not have a cast code like the rest of the IH cast parts. The other numbers are IFC-3 and 8N748. It also came with an adaptor plate to mount to the PTO it has four bolts holes and is called a Belt Pully extison with a TISCO number FM - 521. Im not sure what this is off of but I dont think IH. Im thinking a Ford or something? Would like to what this is for and what I can get for it. I wish I could get a pic but I dont have a camera at this time
Thanks for the help!!!! Andrew
old
05-10-2007 09:27:12
 Re: Belt Pully gear box, no idea what this is off in reply to Andrew Z , 05-10-2007 09:23:01
That number that starts with 8N may tell the story. Sounds like its made to fit on the N series ford tractors like the 8N, 9N or 2N. A lot of stuff made for the N series tractor had numbers that started with either 8N or 9N.
Nebraska Cowman
05-10-2007 09:26:53
yeah, without looking up the nuber I'd say Ford or Ferguson. Any that use the small 1 1/8 PTO. Don't know about the extension, maybe an option so it can be used with tractors with 1 3/8 shaft? They are pretty common but will bring $25 or more on ebay.
Andrew Z
05-10-2007 19:50:14
 Re: Belt Pully gear box, no idea what this is off in reply to Nebraska Cowman, 05-10-2007 09:26:53
Thanks for the help guys!!
Andrew
