IH240U lift
JimbinTexas
05-10-2007 12:04:04
A while back I asked for help with a 240U lift that wouldn't hold it's place. It would either go all the way down or all the way up. Someone told me to check a valve under the seat. I finally got around to taking the seat off, but ran into a solid plate that seemed to be welded in place. It had 4 small holes in it but didn't allow to see under it. Couldn't make out a valve. Any help? JimBinTexas
GA Dave
05-10-2007 18:39:38
 Re: IH240U lift in reply to JimbinTexas, 05-10-2007 12:04:04
My 240U hydraulics has the control lever to the right of the seat. The lever moves very little either way. It hold's at any position when centered but is very "touchy". Try moving the lever slowly to find the center where it will hold that position. You may need to apply some type of friction to the lever if that is the problem. David.
JimBinTexas
05-11-2007 11:57:54
 Re: IH240U lift in reply to GA Dave, 05-10-2007 18:39:38
Dave: My lever is also on the right side of the seat. The lever stays in position pretty much, but is, like you said of yours, very touchy. Someone told me that if it acted like that, there was a valve under the seat which was supposed to stop the implement in its place, when you stopped the lift handle, but could maybe not be engaging properly. Can you see any kind of valve under the seat of your 240U? There is a rod which runs from the handle on the right side, under the seat, to some control rods on the left side, going back to the hydr-cylinder, and forward to some connections under the fuel tank. When not running, I can move the lift handle back and forth and the slack in the connections never do anything to the rod going back to the cylinder. There is a kind of round cam-like deal on the left side that is supposed to move a rod going back to the cylinder, but it doesn't make anything move when you move the handle up and down. Any help? Thanks. Jim
GA Dave
05-11-2007 19:00:16
 Re: IH240U lift in reply to JimBinTexas, 05-11-2007 11:57:54
I have the rod going back to the cylinder also but it's in the box of part's I got with the tractor. Try taking it off to see if it will hold in position. That may be why it won't! David.
