Rear wheel weight questions 460U
Gary in Mozarks
05-11-2007 09:19:25
Wet grass, clay soup = I got the 460U stuck again today in what we call soil. (second time). Tires not loaded. It has a heavy duty loader (brand unknown) on it. I read the old posts and it appears the 2 piece rear weights 365321R2 is the correct weight for the 28 inch pressed steel wheels. Others said they have used Massey harris and cockshutt 2 piece weights that worked. I happen to have a one piece set of weights for a 460 row crop. Has anyone ever made them work on a 28 inch wheel? Any other suggestions? I think I will replace the 600x16 tires on it with 7.50x16 tires. I would think they would handle the front end loader weight better. Any comments?
Butch WI
05-11-2007 10:13:30
 Re: Rear wheel weight questions 460U in reply to Gary in Mozarks , 05-11-2007 09:19:25
Gary,
I will send you a pic of a rear weight on mine tonight. I don't recall if it was one or two pc. would you like any measurements of it?
Butch
