W9 engine parts
railhead
05-11-2007 14:38:19
Does anyone know a source of engine parts (sleeves, bearings, push rods, pistons, etc for W9? Any other tractors/combines interchange? I have one (on LP) that is stuck and the previous owner pulled on it with a dozer to free it and guess what happened inside? Not good. If it cost too much, I may have a parts donor for my running LP 9 on my hands but hopefully it is rebuildable as is.
mulcher
05-11-2007 20:31:00
 Re: W9 engine parts in reply to railhead, 05-11-2007 14:38:19
Did the W9 have a propane head available when they came out new? I have a U9 power unit that was set up for propane and have taken the head off to look at but don't have a gas head off at the moment to compare it to.
Brian
Wardner
05-11-2007 19:24:40
You really should indicate your location when requesting parts or a parts tractor. I could ship you an entire I-9. Are you willing to pay the freight from MA as well as the scrap value of the iron?
It would also help if you would activate your email.
matt moore
05-16-2007 21:06:59
 Re: W9 engine parts in reply to Wardner, 05-11-2007 19:24:40
Hello, I need a rear rim and two rear tires
for an ID 9. Are the W9 and ID9 compatible?
If they are, I am interested and I am located in west central Arkansas. Thanks Matt
Steven@AZ
05-11-2007 18:02:48
Depending on what you need I have some gas W9 parts that should be good. A set of connecting rods and 3 useable pistons, and a decent looking crankshaft....
Weber Tractor Works has NOS parts...
champspa
05-11-2007 15:52:47
weber tractor works has w9 stuff
