400 Throttle Lever
super991/2
05-11-2007 19:43:13
Got my corn planted and started spraying it with the 400. I have to hold the throttle lever down, when I let go of it, it comes up to about 1/2 throttle. I put a new washer on it, the old one was wore. The notches it sets in look to have good square edges. It's a bear trying to hold lever down and turn around and set pressure. Could the return spring be too tight? Is there a special washer from IH that has to be used for this? I just grabbed a new one from bolt bin. Any ideas? Thanks, Chris
Jossette
05-12-2007 16:57:38
 Re: 400 Throttle Lever in reply to super991/2, 05-11-2007 19:43:13
part # 354 746 R1
janicholson
05-12-2007 05:42:19
There is a spring on the shaft that applies pressure to the handle toward the toothed strip of metal. that spring has fatigued and can be replaced with a hardware store spring of the same diameter and twice the wire diameter. in the meantime make a #9 wire hook to fasten under the bottom bolt of the toothed strip, and over the handle shank. JimN
