f12 and c bearings
52G
05-11-2007 20:15:33
Will the rod and main bearings interchange on an f12 and a C or B farmall. Local parts store can't go back as for as the f12, but can do B and Cs. The f12 does have the farmall engine. Thanks for any help.
J.J. from Afton
05-12-2007 07:14:40
 Re: f12 and c bearings in reply to 52G, 05-11-2007 20:15:33
Last year when I rebuilt my F-12 I had to alter the the main bearings. The difference is that the little tabs or whatever you want to call them need to be on the opposite side, but nobody makes them that way that I heard of anyway.
I had to file off the the tabs on the 3 of them that went into the block. Than once they were in place I took a hammer and small punch to make new tabs on them, its no big deal.
teddy52food
05-12-2007 10:32:15
 Re: f12 and c bearings in reply to J.J. from Afton, 05-12-2007 07:14:40
I used a small grinding wheel in a Dremel tool and put a notch in the block for the tabs to fit.
James Williams
05-12-2007 00:01:05
THE BEARINGS ARE SUPOSE TO INTERCHANGE,BUT THERE IS SOME DIFFERENCE,THE LAST TIME I REBUILT A F12 I THINK I ORDERED THE BEARINGS FROM GORDON RICE,OR AT LEAST I WOULD CALL AND TALK TO HIM
JIMMY
I DONT HAVE HIS NUMBER ON HAND BUT YOU CAN GET IT ON THE INTERNET BY SEARCHING FOR RICE EQUIPMENT
52G
05-12-2007 15:50:20
 Re: f12 and c bearings in reply to James Williams, 05-12-2007 00:01:05
Thanks to all of you, that gave me a lot of needed info.
