Super A axle mounting bracket removal
TimnNY
05-12-2007 19:48:33
I"m trying to remove the axle mounting bracket on my Super A to facilitate cleaning and paint prep. I"ve removed the axle and steering column. the bracket has six bolts, that I can see. I"ve tapped, lightly,with a screw driver, the seam between the bracket and the bolster but it dosen"t seem to want to come free. I"ve loosened the bolts, of course, but I don"t want to bugger this. Am I going in the right direction? Thanks
Tim
davset
05-13-2007 15:48:09
 Re: Super A axle mounting bracket removal in reply to TimnNY, 05-12-2007 19:48:33
The steering arm is keyed to the shaft with a woodruff key and the shaft is tapered at that point.
It could be that the key has sheared, in which case it will be significantly more difficult to remove the arm. A combination of tapping, heat, and possibly a gear puller should get it to break free and come off.
VAJerry
05-13-2007 06:43:40
I can take some force. I used a dead blow sledge hammer. It may have been there for 60 years.
banjo
05-12-2007 20:03:20
Have you removed the steering arm?
TimnNY
05-12-2007 20:20:30
 Re: Super A axle mounting bracket removal in reply to banjo, 05-12-2007 20:03:20
I haven"t removed the center steering arm. I was able to remove the castle nut but The arm, itself. is resistant and, again, I am hesitant to "strong arm" it off. I thought it would come, complete, with the bracket.
TmnNY
05-13-2007 10:47:11
 Re: Super A axle mounting bracket removal in reply to TimnNY, 05-12-2007 20:20:30
OK, It looks like the steering arm has to come off first. There apears to be a woodruff key but I don't see that it is fitted into the shaft. Suggestions on best avenue of attack. Heat? Again, I am reluctant to do more than "tap" the arm. The castle nut has been removed. I'm frustrated at the moment.
