another S A headgasket question
gmsuper A
05-13-2007 10:26:31
I have read the posts on the SA headgaskets good info my question is I put a new headgasket on my 51 sa it is all stock. but I put a water pump on it just to keep the water moving in system the tractor will be just used for play.Did I put the right gasket on it for a water pump.Also my gasket seems to leak some oil out the sides I put sealer on and re torque the head after a good warm up. anybody have a thoughts on this. Thanks for all the help
CNKS
05-13-2007 19:49:17
 Re: another S A headgasket question in reply to gmsuper A, 05-13-2007 10:26:31
You use a different gasket when it is a C123, which has smaller passages, they all had water pumps. You put a water pump on a themosiphon tractor, therefore you still use the thermosiphon gasket because you did not change the head or block.
Hugh MacKay
05-13-2007 12:36:28
gm: When I did my SA, the technician wanted me to work it hard for 4 to 5 hours. Maybe you should work it more than retorque again.
I think having the right gasket is most important if thermosyphon. It may be as important to have the right one for the water pump as well, however probably not crucial. Someone will jump on me if wrong.
Janicholson
05-13-2007 15:52:15
 Re: another S A headgasket question in reply to Hugh MacKay, 05-13-2007 12:36:28
Hugh, you are exactly correct. The smaller ports in the "Pump" gasket assists coolant flow to the rear of the block/head. Unless the unit is running with a radiator that just marginally keeps it cool, it will be fine. JimN
