F-30 Engine Part Numbers
BT in NE
05-13-2007 19:55:24
Thanks to everyone who helped on my last post about my brake trouble. I did get them unstuck but ended up breaking the shoe on each side with the thicker "pivot" end. Put drum back together just so it can be moved for now. My question this time is about the engine. Pulled the head and noticed the pistons have a chamfered edge with a flat top. Is this a high altitude? They are cast iron. I can't see any marks on the pistons other than a single letter; D,E,F, etc. I found a stamp on one of the sleeves that has IHC435D. Can anyone tell me what this means? Checked my parts book and doesn't show this number. I am still trying to get it unstuck so will post if all is OK. Sorry for the rambling, thanks all. BT
Nebraska Cowman
05-14-2007 04:14:16
 Re: F-30 Engine Part Numbers in reply to BT in NE, 05-13-2007 19:55:24
Yes, those sound like high compression pistons. 435D is the correct sleeve number. Your parts book might show the number with an "X" which is Assy with probably the packing rings.
