6 volt battery cable size???
redlin49
05-13-2007 21:26:36
What gauge battery cable and starter cable should I use on a 6 volt positive ground system? 1/0 or 2/0?
Red Dave
05-14-2007 05:01:00
 Re: 6 volt battery cable size??? in reply to redlin49, 05-13-2007 21:26:36
#1 is the minimum, 00 is better, 1/0 is even better yet, but I have found that 2/0 is hard to get into most battery connectors.
Bigger is better, and be sure to keep those connections clean, bright & tight.
Hugh MacKay
05-14-2007 03:03:04
redlin: Go with Jay's advice, too small cable are the single biggest reason why 6 volt systems don't work well. 12 volt is no different when you get into big diesels like trucks. In fact in this age in time big truck shops are the best place to find those big cables. They will make them up to the exact length you need, and will solder the ends on, very important.
It will cost you $25. but you save it in grief, batteries and starters.
JayWalt
05-13-2007 22:04:14
the bigger the better within reason
I would go with the 00 if its not much more exspensive.
