1566 3pt Lift Lever
Mitchissippi
05-14-2007 14:25:03
The 3 point hitch seems to work fine on our 1566, but the lever will not stay in the rised postition. by itself. I've been using a grader blade, so one hand is almost always on the lever at all times. When I've needed the keep it up, I've been clamping a pair of small needle nose vice grips ahead of the lever to keep it back.
Whats the fix for this?
Thanks!
Mitch
Allan In NE
05-14-2007 16:00:39
 Re: 1566 3pt Lift Lever in reply to Mitchissippi, 05-14-2007 14:25:03
Tighten the clutch at the base of the lever with a 1/2" socket. Takes about 2 1/2 seconds.
Allan
