shredding with Farmall A
Terry Mayfield
05-14-2007 20:27:46
what about pulling a shredder with an A. What size shredder, do I need a Clutch on the PTO?
NawlensGator
05-15-2007 07:35:02
 Re: shredding with Farmall A in reply to Terry Mayfield, 05-14-2007 20:27:46
I've use the offset PTO (IH 140) with a 6' woods finish mower centered between the tractor rear wheels. The drive shaft is cocked at both 'U' joints. The 'U' joints are still going strong after over 20 yrs mowing. Centering the mower with the tractor sure simplifies things.
marty johns
05-14-2007 22:18:58
I have a 45 farmal A that I pull a 5' King Kutter with! the 1st cut in late may early june is a bit rough on her as I only use 1/2 to 2/3 of the mower, but later in the summer when then the grass is'nt growong as fast or as thick, she'll do the whole 5'
georgeky
05-14-2007 20:38:14
My father in law pulled a 7 foot Bushhog with his B and mowed thick grass and everything with it. I pull that same mower now with a C. You do need the over running clutch on your tractor shaft.
Terry Mayfield
05-14-2007 21:26:08
 Re: shredding with Farmall A in reply to georgeky, 05-14-2007 20:38:14
thanks for the reply, I'm looking at a 5' pull shredder, what about the PTO shaft being off center on the A
gene bender
05-15-2007 00:15:36
 Re: shredding with Farmall A in reply to Terry Mayfield, 05-14-2007 21:26:08
Just hook the tounge of the shredder in line with the pto sure will save the u-joints.
