F20 Overhaul
GAUU6
05-15-2007 08:09:17
I can't find the connecting rod cap bolt lock (47 496 DB)locally. Are they available anywhere? Can they be replaced with a lock washer? Thanks
El Toro
05-15-2007 09:11:25
 Re: F20 Overhaul in reply to GAUU6, 05-15-2007 08:09:17
If the rod bolts have holes drilled in them you could use twisted safety wire. The Air Force use
this on aircraft engines. They make a tool for twisting the wire too. Hal
BF8690
05-15-2007 09:28:06
 Re: F20 Overhaul in reply to El Toro, 05-15-2007 09:11:25
So does the Navy. The tool is called safety wire pliers.
El Toro
05-15-2007 12:23:42
 Re: F20 Overhaul in reply to BF8690, 05-15-2007 09:28:06
Here's the web site. Hal
www.safetywirepliers.com
El Toro
05-15-2007 12:20:41
The Army used it their tank engines. Hal
RustyFarmall
05-15-2007 08:41:17
Would it be possible to use a fender washer? Those are basically a flat washer with an extra large diameter. Might need to grind part of the washer away to make it fit the rod cap, then just hammer the rest of it down to provide a "lock".
Glenn F.
05-15-2007 09:49:52
 Re: F20 Overhaul in reply to RustyFarmall, 05-15-2007 08:41:17
Seems like a fender washer would work real well if it's made of hard enough material to withstand/maintain the torque rating.
Glenn
RustyFarmall
05-15-2007 11:59:28
 Re: F20 Overhaul in reply to Glenn F., 05-15-2007 09:49:52
Yes, and I am not sure of the strength rating.
