Rear Combo Light
sflem849
05-15-2007 17:52:03
I recently recieved a rear combo light w red jewel light inside the light. Upon testing I believe I found out the 1133 bulb is a 6 volt. Eh, I am over that. It wouldnt have done me any good...Am I correct in that to make the light 12v is put a 12v bulb in?
I also have two other questions. When I took the light apart the white bulbs wire was screwed to the lower hole and the red bulbs wire was just floating in there. Where is the power supposed to come into the light?
Also, the switch was gone from the top of the light. Where would I go about getting a new one? I have seen them in OEM but the $25 price tag is PRETTY steep.
How does the light mount to a SMTA? MD? the OEM book has it coming through the battery box on a pipe...That is where my ground cable comes through.
Last question. Could a tractor have sealed beams on front and regular bulbs in back? (why are my sealed beams white?) (I know these are tough with just about anything flying from the IH factory)
Bob M
05-15-2007 19:35:21
 Re: Rear Combo Light in reply to sflem849, 05-15-2007 17:52:03
"Am I correct in that to make the light 12v is put a 12v bulb in?"
Yup!
"Where is the power supposed to come into the light?"
The red-white selector switch will have 3 terminals. Power from the main light switch goes to the selector switch common terminal. The red and white light feed wires connect to the other two switch terminals (doesn't matter which wire goes to each terminal...)
"Where would I go about getting a new one?"
Unless you are a stickler for originality a single pole double throw toggle switch (a couple bucks at Radio Shack) works fine.
"How does the light mount to a SMTA? MD? the OEM book has it coming through the battery box on a pipe..."
My SM has it mounted on a stub of bar stock bolted to the side of the battery box. I don't know if it's original or a modification by the previous owner....
"Could a tractor have sealed beams on front and regular bulbs in back?"
I believe that's how the seal beam-equipped tractors came from the factory.
