Order Farmall Cub Parts Online
1948 Farmall Cub Hydrolic leak
Roger Kansas
05-16-2007 09:45:46
Help I have a small leak from the hydrolic container under the fuel tank I have removed the fuel tank. Do I need to take the Hydrolic unit out of the tractor to repair or can I tear it down in the tractor. I may as well replace all the seals while I am at it so what seals need to be replaced and where can I get them. The leak is not bad but I want to fix it before I paint.
Roger Kansas
05-16-2007 10:35:23
 Re: 1948 Farmall Cub Hydrolic leak in reply to banjo, 05-16-2007 10:08:31
Thanks It looks like the leak is from the cylinder in the bottom front of the container do you think I should just rebuild that or do a complete rebuild.
banjo
05-17-2007 20:00:28
 Re: 1948 Farmall Cub Hydrolic leak in reply to Roger Kansas, 05-16-2007 10:35:23
That's up to you. If it was me i would do the complete rebuild knowing it was all done and should last for a long time.
