Order Farmall Cub Parts Online
Cub pto and transmission oil
mikeinLA
05-16-2007 10:30:12
What weight/type of oil do I put in the PTO and transmission of my Cub tractor. The rear oil seal was leaking and I need to replace the oil.
Denny ('60 Lo-Boy)
05-16-2007 14:25:50
 Re: Cub pto and transmission oil in reply to mikeinLA, 05-16-2007 10:30:12
Note that it only holds 3 1/2 PINTS, not quarts. Leaking seals are usually caused by overfilling and/or water & condensation.
glennster
05-16-2007 10:58:02
you can run any gear lube 80wt to 140 wt, or a multi vis like 90w140 too.
