two point hitch plow for a 300 Utility
Earl from PA
05-16-2007 17:06:52
Can anybody tell me if there is a difference between a two bottom two point hitch plow with the heavy two point prongs for a 300 Utility and a 300 Farmall? I have found a very nice two bottom two point hitch plow but I'm not sure if it will fit my 300 Utility. All paint and markings are rusted off. Thanks for any input.
georgeky
05-16-2007 17:23:00
 Re: two point hitch plow for a 300 Utility in reply to Earl from PA, 05-16-2007 17:06:52
As long as it has the large prongs it will work. If you post a picture of it me or someone else can tell you the model number.
formerly ny bill
05-16-2007 19:32:58
 Re: two point hitch plow for a 300 Utility in reply to georgeky, 05-16-2007 17:23:00
even a plow with the small prongs will work on a 300, as long as spacer bars are used with it. the hitch size is the same for a farmall 300 and a 300 utility.
georgeky
05-16-2007 20:50:55
 Re: two point hitch plow for a 300 Utility in reply to formerly ny bill, 05-16-2007 19:32:58
Yes,they will. I have a grader blade and model 100 mower that are set up that way now to fit my 350.
