Priming live hydraulic system on 400
Big Country
05-16-2007 19:02:59
Is there a specific way to prime the hydraulic system? I would appreciate any help, as I don't want to screw anything up. I have shop manual but can't find anything in the book about priming the system.
JayWalt
05-16-2007 21:54:34
 Re: Priming live hydraulic system on 400 in reply to Big Country, 05-16-2007 19:02:59
i think the 400s are differnet from my 300u, but I did as wardner said. I cracked the hardlines at the pump and pressurized the resevoir until oil could be seen at the pump, then tightened her up and shes good to go!!
If the pump has been apart make sure u used plenty of assembly lube, if you didnt, take it back apart and lube it, not worth ruining the pump from lack of initial lube. If the pump has been sitting dry for some time (like years), I would defintiely pressurize the resevoir, probably while cranking the engine a bit to get the pump going (unhook the coil power wire or something).
JayWalt
05-16-2007 21:55:38
 Re: Priming live hydraulic system on 400 in reply to JayWalt, 05-16-2007 21:54:34
oh, btw, set ur regulator to around 10-15lbs, no more is needed, and can rupture resevoir gaskets which arent fun to replace.
Wardner
05-16-2007 20:14:20
The advice normally given on this board is to pressurize the reservoir. I don't know if that works because I would think both the inlet and outlet of the pump would be affected and there would no pressure differential.
I do it differently and I believe it is the way the manufacturer intended.
At the top of the pump, you will see a little bleeder ball that is held in place with a concealed spring. Both the Pesco and Thompson pumps have it. Hold that down for a few minutes with the engine off. If that doesn't work, make something that will move the ball and place a heavy weight on it. Let it sit overnight or until oil leaks out.
