head gasket dope?
BustedKnuckles
05-17-2007 02:11:33
I'm putting the head back on my Jeep CJ2A ('47) flat-head motor. Is any compound (dope) such as gaket- sealer, PeraTex necessary ? The gasket is a FelPro metallic-type with no instructions. listed on shipping carboard. If so, both sides? Block side? Head side? Or not at all? Thanks. BustedKnuckles
BF8690
05-17-2007 09:34:04
 PS in reply to BustedKnuckles, 05-17-2007 02:11:33
Don't mess with peratex or gasket shelac. It has a tendancy to make cork/paper gasket brittle and hard to remove. I realize that your head gasket is not of either of these types but it is still good to know.
BF8690
05-17-2007 09:32:15
 Re: head gasket dope? in reply to BustedKnuckles, 05-17-2007 02:11:33
A freind of mine is a mechanic and he turned me on to two good ideas that have worked very well. The first is hair spray for any rubber hoses. They slip on easy and after the hair spray drys with the clamps tight it never leaks. The second is 3M contact cement, the spray can kind. I spray it on all gaskets. It seal them and also makes it very easy to removed the used gasket with very little scraping. Both work like a champ.
F-Dean
05-17-2007 06:05:04
I use grease on my old 1930s IHC tractors. If you have to take it off in the near future, it is not a difficult task.
Dave S.
05-17-2007 02:49:39
If it is metal spray it with aluminum paint or coat it with Copper Kote on both sides and install. It will work fine. Dave
