IH 506 located
Tom in Mo.
05-17-2007 19:22:35
I have searched the archives about the 506 and nobody knows that any were made. I know where one is sitting right now with a can on the exhaust and obviously hasn't run in a few years. It is a four cylinder gas with a 506 badge on the hood side panel. Was this a transition model of some kind?
Nat 2
05-18-2007 05:59:41
 Re: IH 506 located in reply to Tom in Mo., 05-17-2007 19:22:35
The "6" at the end of the model number indicated the number of cylinders in the engine from 1964 through 1981. 4-cylinder tractor model numbers end in a 4.
To the best of my knowledge, there was never a "506" built for the North American market, let alone an "06" with a 4-cylinder engine. There was a 404, 504, 606, 706, 806, 1206.
You may be looking at a 560, and your mind got the numbers reversed as you drove by at 55MPH. You may also be looking at a 504, and simply misread the badge as you drove by at 55MPH.
Tom in Mo.
05-17-2007 19:43:29
OK I'll check it out again tomorrow. Maybe it's got some old and wrong hood badges on it. Thanks for the replys.
CNKS
05-17-2007 19:40:27
No 506's, I believe you are looking at a 504 -- Take a look at the serial tag. There is also a 606, it is a utility, but it has 6 cylinders.
georgeky
05-17-2007 19:34:15
A 4 cylinder would not end with 6.
