Order Farmall Cub Parts Online
48 Farmall Cub Rod Bearings
Mark JF
05-18-2007 10:50:08
How hard to replace rod bearings in a Cub? Here is my problem. When the motor runs at normal or high RPM's it sounds fine. But when I lower the throttle so the motor is bearly idleing I can hear a knock in the motor on the carb side. Oil pressure is real good the needle stands right in the middle on low idle. Does this sound like a rod knock? What else could it be?
Thanks in advance.
Mark
Janicholson
05-18-2007 14:57:58
 Re: 48 Farmall Cub Rod Bearings in reply to Mark JF, 05-18-2007 10:50:08
El Toro may be correct on the wrist pin. Ifyou move the throttle while listening, and at some critical rpm it becomes intermittant, then goes away, I would also suspect a pin. They can run for a long long time wth a loose pin, but not a bad rod!. Do as El Toro suggests, and check the rod bearings with plastigauge. Adjusting the valves might also be a noise eliminator. JimN
El Toro
05-18-2007 13:28:32
You can plasti-gage the rods to see how much clearance you have. Take a good look at the rod journals to make sure they're still nice and smooth. You may be hearing a wrist pin that's too loose. Hal
