Farmall H Coolant flow question?
Aaron B
05-18-2007 18:02:13
I am beginning to reassemble my Farmall H, now that my gasket set has arrived. Unfortunately, I have forgotten one minute detail---should the access panel on the left hand side of the block deflect the coolant upwards or downwards? The coolant is forced into this part of the block by the water pump, and the access panel has louvres to direct the flow, but I have forgotten which way it was when it came off. I really appreciate anyone's help. Thanks!
Aaron
D Slater
05-19-2007 18:46:53
 Re: Farmall H Coolant flow question? in reply to Aaron B, 05-18-2007 18:02:13
Down
Steven@AZ
05-18-2007 19:55:27
If I remember correctly the bolt holes only line up one way... and every one that I have seen has "TOP" stamped in it.
Tom Windsor
05-18-2007 18:19:41
Aaron
You are talking over my head here. There is no access pannel on the left side of this block that keeps water in! Are you speaking of the cover where you access the lifters?
TW
CNKS
05-18-2007 18:45:16
 Re: Farmall H Coolant flow question? in reply to Tom Windsor, 05-18-2007 18:19:41
You better look again. If it hasn't ever been replaced, the inside is rotten. Lifter cover is on the right side.
Tom Windsor
05-18-2007 19:18:23
 Re: Farmall H Coolant flow question? in reply to CNKS, 05-18-2007 18:45:16
Well, I thought you were a little whackie...so I went down there and looked...Lo and behold, there it is...marked top and properly installed...after all...it has been 30 days since I installed it!!!! Senility. :-)
TW
CNKS
05-18-2007 19:36:11
 Re: Farmall H Coolant flow question? in reply to Tom Windsor, 05-18-2007 19:18:23
If you looked at some of the things I have done, you would think you were Einstein.
dcw
05-18-2007 18:18:46
That panel should have ''TOP'' on it,mine does.
