Electrolysis, IH 240 rear wheel weights
GA Dave
05-18-2007 19:22:43
third party image
Made a cooker yesterday. Seven narrow stainless strips around a 32 gallon trash can hooked together with copper wire. I used 15 ounces of Arm & Hammer /Powerfully Clean/ Naturally Fresh/ Clean Mountain /with Activated Baking Soda Deodorizer out of the laundry aisle with 30 gallons of water. Sixteen hours of cooking @ 6 amps and what a suprise. I'm going to let it smolder until tomorrow. Sure beats wire grinding. Trying to send a picture. David.
GA Dave
05-19-2007 18:19:20
 Re: Electrolysis, IH 240 rear wheel weights in reply to GA Dave, 05-18-2007 19:22:43
Gene, one tablespoon per gallon of water. The store I went to only had this brand and I couldn't ask for better results. I'm sure the main ingredient is sodium carbonate. David.
Karl Hamson
05-19-2007 12:28:27
I have heard that using stainless as an anode will make your electolyte toxic with some kind of chromium derivative. Scrap steel will not do this and works just as well.
GeneMO
05-18-2007 21:20:33
I started a tank about a month ago. I have had excellent results with mine, although I used about 10 times too much soda. I was told to use Washing Soda. Found in laundry isle, but not baking soda. Not sure which you used. Hey if it works, what the heck!!! I just wish I could get my Super H hood in there, gonna be a tight fit. I started with a 50 gallon plastic drum. There is tons of information if you do a search on this site.
Gene
