1966 Farmall 656G Hydraulic Housing Drain Plug
North TX 656G
05-19-2007 12:09:33
third party image
Hi, I just purchased my first Farmall. I'm changing out my fluids but I can't locate #28 in the picture, described in the owners manual as the "Hydraulic Housing Drain Plug". (I checked the archives first but struck out) Thank you for any knowledge you can provide.
Allan In NE
05-19-2007 13:38:00
 Re: 1966 Farmall 656G Hydraulic Housing Drain Plug in reply to North TX 656G, 05-19-2007 12:09:33
That is a bit misleading, isn't it? :>)
The picture is pointing at the third point/fast hitch arm lockout so simply can't be a "plug".
The manuals were written and published far before the tractors even went into production, so there are errors found from time to time.
The drain back is actually located inside the hydraulic housing and you don't even have to concern yourself with it..... ..
Allan
North TX 656G
05-19-2007 19:47:28
 Re: 1966 Farmall 656G Hydraulic Housing Drain Plug in reply to Allan In NE, 05-19-2007 13:38:00
Thank you. Next I apparently need to make a tool to remove two of the three bottom drain plugs. 1/4" socket head is too small, 3/8" is too large. Does everyone just grind down a 3/8" extension to fit the bottom plugs?
Allan In NE
05-20-2007 01:57:49
 Re: 1966 Farmall 656G Hydraulic Housing Drain Plug in reply to North TX 656G, 05-19-2007 19:47:28
Yes,
I just went thru this on a head. Took an old extension that the ball had fallen out of and carefully ground it down to 5/16".
Worked like a charm.
Allan
third party image
North TX 656G
05-19-2007 12:12:24
third party image
Pic #3
North TX 656G
05-19-2007 12:10:57
third party image
Pic #2
