Order Farmall Cub Parts Online
Cub PTO
Farmall Ed
05-20-2007 05:55:16
The PTO on my 48 Cub will not engage, With no load it seems to engage but pops out as soon as you let the clutch out. I have been in there a couple of times in fhe past and I dont understand what would cause this. Any advice would be appreciated. I do have the parts manual so you can get technical if need be. Thanks Ed
Bigdog
05-20-2007 06:39:17
 Re: Cub PTO in reply to Farmall Ed, 05-20-2007 05:55:16
There are several possibilities. First check for end play. It is possible the hardened pin that engages the shift collar is worn and is not allowing the collar to engage far enough. Try loosening the quadrant on the engagement lever and see if you can push the lever far enough forward to get good engagement. If you can, then I'd pull the lever assembly and check the pin. If there is a lot of end play in the pto shaft you will want to check to see if the snap ring bearing retainer is still in place or if it is the older style that is staked to the shaft you will want to assure that the bearing has not moved on the shaft.
