How to remove the old valve guides
Brad in WI
05-20-2007 10:07:40
What is the easiest way to remove and install the valve guides on a farmall H.. Just got my overhaul kit last week and now is the time to try to figure out where everything is supposed to go
the tractor vet
05-20-2007 10:39:24
 Re: How to remove the old valve guides in reply to Brad in WI, 05-20-2007 10:07:40
Well ya could have the machine shop do it whiel they are doing the valves of ya could have a machine shop make up a driver and just beat them out . when i would remove and install guides i used the press with the proper tooling.
Brad in WI
05-20-2007 11:43:00
 Re: How to remove the old valve guides in reply to the tractor vet, 05-20-2007 10:39:24
also what is the proper tooling to remove and install the guides.
the tractor vet
05-20-2007 16:13:49
 Re: How to remove the old valve guides in reply to Brad in WI, 05-20-2007 11:43:00
The tool or tools that we had were made from tool steel with a tip that went into the guide and was just a wisker smaller then the hole in the guide and had a larger shaft for driving on or pushing on , where the flage meet the top or bottom of the guide it was machined back so it would not fold the metal around the hole to cause the hole to get tight on the valve stem also had the reams to clean them up . At one time my buddy and i had everything to do heads with , had the head surface grinder tooling to install guide in heads that had the guide cast into them tooling to install seat had it all . It was all in good shape but old and slow . Had a nother buddy that had and engine machine shop with the latest and greatest state of the art stuff he could do the job faster then we could for less . like boring and engine with his big stationary boring bar he could bore and finish hone and engine in the time it took me to do three holes and with him doing them i did not had to fight that 250lb. portable bar over each hole . Went back to just twisten wrenches as my time was better spent .
Brad in WI
05-20-2007 10:57:39
the valve seats are done already. I did not think I was going to get new guides but they came in my overhaul kit. do you pound them into the combustion chamber or up towards the rocker shaft. I tried pounding on one going down and all it did was mush the end of it
the tractor vet
05-20-2007 11:08:14
 Re: How to remove the old valve guides in reply to Brad in WI, 05-20-2007 10:57:39
Well if ya are going to put in new guide then the seat ARE NOT DONE as the new guides will and you can take this to the bank will not seal wright as they will be off.
Brad in WI
05-20-2007 11:41:42
 Re: How to remove the old valve guides in reply to the tractor vet, 05-20-2007 11:08:14
so let me get this straight when I put in the new guides I will have to have the new seats recut by a machine shop. that way everything will run true and hopefully not leak.
MN Scott
05-20-2007 15:20:44
 Re: How to remove the old valve guides in reply to Brad in WI, 05-20-2007 11:41:42
Correct. Were your old guides worn? Or are you just replacing them because they came with the kit? In my experence the guides often are in good shape, its the valves that need replacing on an H. Also those new guides will most likelly need to be reamed so the valves fit correctally. So to sum it up, head and valve work is best left to a good machine shop unless you have the proper equipment and knowlage to do the job.
El Toro
05-20-2007 12:34:16
I think your own machine shop will tell what the
TractorVet has said. Hal
