Ser numbers and codes
HENRY E NC
05-20-2007 12:04:25
Since I have lent all my Farmall books to a friend I can't look up some things. The serial # on the motor block (A) is 190186 and the casting code ends in C so I imagine this is not an orginal engine for a 41 A.. Help Please
El Toro
05-20-2007 16:11:15
 Re: Ser numbers and codes in reply to HENRY E NC, 05-20-2007 12:04:25
The engine may be from a Super C. Does the engine have a water pump? Does it have C123 on the block? Hal
Red Dave
05-20-2007 15:59:20
The serial number 190186 suggests a 1947. But the casting code for a "C" year would be either 1933 or 1957. Neither seems to go with the serial number.
I'm not quite sure what you have there.
