Need help with glue
tractor hank
05-20-2007 20:10:36
I have some steel wheeled tractors that I have made steel parade belts for the wheels and I am getting ready to attach some rubber belting material. I use elevator bolts to attach the rubber belting to the steel rims but I need a real good glue also. Any advice or suggestions on the type of adhesive to use would be appreciated.
Janicholson
05-20-2007 21:04:11
 Re: Need help with glue in reply to tractor hank , 05-20-2007 20:10:36
Rough up both the steel (with 40 grit), and the rubber (contact surface with 80 grit) and use weldwood contact adheasive. Do it outside, follow the directions, and don't breath the fumes. Use a rubber mallet to adhear the rubber. JimN
