Update on Tractor And Planter
El Toro
05-22-2007 06:55:06
third party image
The planter has been repaired and the farmer was not injured and is busy planting. The total tally is not in, but they think it will be in 5 digits for the recovery. Hal
J.J. from Afton
05-22-2007 11:21:05
 Re: Update on Tractor And Planter in reply to El Toro, 05-22-2007 06:55:06
I read somewhere that the tractor weighed about 13 tons, the planter about 9.5 tons, and the bridge was built to hold 10,000, maybe 15,000 pounds. So there was just alittle bit of difference in those numbers.
El Toro
05-22-2007 11:54:30
 Re: Update on Tractor And Planter in reply to J.J. from Afton, 05-22-2007 11:21:05
Those side tanks were filled too probably need to add several more tons. Hal
neblinc
05-22-2007 07:34:55
Bet he will have 2nd thoughts on crossing that bridge again if they repair it.
Randy
El Toro
05-22-2007 07:49:03
 Re: Update on Tractor And Planter in reply to neblinc, 05-22-2007 07:34:55
That bridge wasn't designed too good. It's hard to say what all that equipment weighed. Those side tanks were probably filled too. Hal
KIP in MX
05-22-2007 08:09:32
 Re: Update on Tractor And Planter in reply to El Toro, 05-22-2007 07:49:03
Yep, looks like tanks weren´t empty. They´re pumping them out into the tank on the trailer.
