F12 rear main seal
LKM
05-22-2007 19:05:05
Hey Guys Is there a smart way to put fit a rear main felt seal in the F12, or is there another type seal I can use to fit the seal groves of the F12? The felt seal I have fresh out of the gasket set is about twice the thickness of the seal groves and is like putting ten pounds of (you know what) in a five pound bag.
James Williams
05-23-2007 03:21:14
 Re: F12 rear main seal in reply to LKM, 05-22-2007 19:05:05
can you replace the seal without pulling the motor
jimmy
John M
05-23-2007 03:19:27
Soak it in oil them put it in.
pgo12
05-23-2007 01:28:03
use the whole felt seal. dont cut it. just slowlly stuff one end in and work your way to the other end. same with the other half. i use a screw driver. it will fit. pg
