Model 31 McCormick loader?
W4
05-23-2007 22:01:41
I'm looking for one of the shoulder bolts that the trip bucket pivots on and one manure fork. I was wondering if anyone could tell me where I might find these parts available. Thanks for any help!
Brownie450
05-26-2007 04:55:17
 Re: Model 31 McCormick loader? in reply to W4, 05-23-2007 22:01:41
All you need is a 3/4 inch bolt & have a bushing made with 3/4 inch id, & outside dimension the same as the bucket hole-- I think ours is 1 1/4 or 1 1/2 inch. Use a thick flat washer on the inside under the bolt head. The original had a 3/4 inch fine thread on the outside & probably was grade 5 or 8. I can measure our bolt if you need dimensions.
RustyFarmall
05-24-2007 04:03:56
You might check with a Case-IH dealer on the bolt, he may be able to come up with something that would work. I have a feeling that the bolt is not a standard issue shoulder bolt, but you might also check out Fastenal, MSC, or McMaster-Carr. Another option is to take the bolt you have to a machine shop and have one made. Finding that tine for the bucket will be tough, unless someone has a #31 for parts.
