Need help identifying IH model
Parish Mills
05-25-2007 06:27:00
We're in the process of restoring an IH tractor and I'm looking to get a service manual for it. Problem is we don't know exactly what model it is. I think it might be a 2400 (it has a diesel engine), but I'm needing someone else to confirm. I'm also curious to know what year model it might be. The only ID tag I could find was on the left hand side of the transmission and read as follows:
Model: T2400D-A
SN: 223006OU002539
Milton
05-25-2007 08:05:17
 Re: Need help identifying IH model in reply to Parish Mills, 05-25-2007 06:27:00
Parish Mills, --- 25 / May / 2007 --- Your International T 2400DA is a Indstrail
tractor with a Diesel / most likely a D179 / 3 cylinders (motor was made at the IH Plant in German).
The I 2400A was made from 1970 to 1974.
S# 223006OU002539 should read as ----- ----- ---
S# 223006(O)0U002539 was most likely made in
1970. This I"m checking out to be sure.
EMail me at "farmall28@yahoo.com" if you need more info.
Milton
