F20 raken hay.
J Muehring
05-25-2007 07:31:00
I spent two days this week raken hay for my cousin using my 36 F20, pulling his NH rake. It was almost as good as plowing, but used less gas. Had a little trouble staying ahead of his D19 with NH round baler cause hay was light and had to triple rake winrows. I was useing 3rd direct and 1st over drive depending on ground cond. Most trouble I had was with govenor not responing correctly. I had to goose it with the throtle to speed engine up. Always going to fast or to slow, any comments would be welcome.
UTURN
05-25-2007 08:06:30
 Re: F20 raken hay. in reply to J Muehring, 05-25-2007 07:31:00
Lucky dog
I would love to get my old 1940 ut minnie out in someones field pulling a old trip plow just to see how it would do. Love to run that old iron have fun uturn
Bob Kerr
05-25-2007 07:57:52
The governor problem might be from a little slop in a spring. If your F-20 has the same type governor my 10-20 had it will have a pot metal tube with one end closed coming off the side of the housing. I turned that tube a little bit and it snugged up the spring and it did well after that.It would either run at idle or wide open before I adjusted the spring in the tube. I raked hay a few years ago with my 35 F-12 and it did great, but I didn't have a baler chasing me. The F-12 is going on a rescue mission today to drag my M up a hill where the clutch blew so I can fix it.
