Order Farmall Cub Parts Online
Cub Ignition follow up
Lloyd1 in CT
05-25-2007 07:52:38
Upon removing the mag on the cub,found that the points had a come apart at the arm..Nvere saw that before. Put new points and a condenser in,cleaned the plugs,re timed and it started on a half crank, just like it should. Just thought I would follow up and say thanks for all the input !
From Eastern Ct
Andrew Z
05-25-2007 09:18:49
 Re: Cub Ignition follow up in reply to Lloyd1 in CT, 05-25-2007 07:52:38
where abouts are you in eastern ct. Im from brooklyn, stop by if your in the area.
Andrew
