white C's revisited
REDd REAPER
05-26-2007 18:12:15
I posted this over on the Red Power Board also, but knew you guys know alot about letter series.
I picked up a C with very old paint, that has white underneith. BUT I had written down in my serial guide that white C's started with the first serial no. of 1950 which was 47010-54411 being the last, and mine is 46368. The casting codes are towards the end of dec. 49. Believe the letter to be a S in the date codes. Also has a letter cast into the platform that someone told me pertained to the white ones, which is a L that is cast by itself.
If the white tractors were introduced in the begining of 50, then surely some were made towards the end of 49 for delivery the first part of 50 correct?
anyone have a clue? its deffinately white underneith.are there any identifying parts or marks to look for? thanks
CNKS
05-26-2007 19:21:40
 Re: white C's revisited in reply to REDd REAPER, 05-26-2007 18:12:15
If you look at the other castings on your tractor, you will find the "L" for Louisville on most of them. ALL C's were built at Louisville, white or not. Generally the white tractors, unless someone faked them will have white in most of the out of sight places. Since they were supposed to be repainted red by the dealers, and the dealers did little disassmebly, look for white paint on the rear side of the battery box, on the valve covers, underneath the hood, inside the grille and other out of the way places. Your serial is close, and as Guy says, the exact serial range is not known, but the 47010-54411 is pretty close. During that 3 month period IH produced an average of about 82 C's per day. Yours is about 8 days production prior to the assumed start. The 3 month period is supposed to be (Guy can correct me), Jan, Feb, March of 1950, PROVIDED the numbers are by the calendar year. If by fiscal year, they are I believe, Nov, Dec, Jan, in which case you would have casting codes back to Sept or Oct 1949, so I doubt if yours was painted white. The white could be primer from a repaint. Check and see if you see red under the white, then white under the red. Most repainted tractors had little or no surface preparation, so the red came off fairly easily.
Guy Fay
05-26-2007 19:02:32
The L in this case just stands for Louisville, the part was cast at Louisville. M was Milwaukee, TW or CTW intertwined was Chicago Tractor Works, F for Farmall Works, etc, totally different format than the date codes. No relationship with the white demonstrator program.
The serial number ranges out there are rough guestimates, there's no known documentation with a serial number or date of first white demonstrator produced.
jonnnny2006
05-26-2007 18:33:57
The cast code "L" Was used in the year 42 So the platform top must of been replaced. the cast code "S" is the year of 49 If you got the list of demo C's and your s.n. is not included then it was a dealer convert or a farmer/owner had it painted white at one time. Farmall had its dealers paint tractors during the slow times and also people repainted tractors too. if you have a 49 and it got just 1 paint job every ten years it would of had almost 6 paint jobs over that time period. though it probally hasent been painted that many times it gives you a perspective of how many times it could of been painted. just enjoy it, as if you cant talk to the people that owned it in the past it is nearly impossible to know what has been done to it over its life. take care
jonnnny2006
