removing steering gear arm
Terry Mayfield
05-27-2007 07:29:29
how do you get the arm out from under the steering box ? do you have to drop the front axle ? I have it loose on the shaft but not enough room to get it out.
Terry Mayfield
06-05-2007 06:13:03
 parts manual in reply to Terry Mayfield, 05-27-2007 07:29:29
I have been trying to open the parts manual on the cleancompute site, I got it open a week ago but now it won't open. Any suggestions ?
gene bender
05-27-2007 12:45:39
 Re: removing steering gear arm in reply to Terry Mayfield, 05-27-2007 07:29:29
Yes you have to remove the axle then take the bolts that hold the steering sector together out so the arm can come off as the bottom of the sector is removed the bottom doesent have to be dropped very far and the arm will come off the shaft.
