1949 M galloping at high speed
G. Anderson
05-27-2007 12:48:43
Why does my M gallop at high speed in 5th gear?
leroy in ne
05-27-2007 16:42:03
 Re: 1949 M galloping at high speed in reply to G. Anderson, 05-27-2007 12:48:43
nylon tires will develop flat spots when setting, tire will be out of round wntil warmed up by using for a while? fluid in tires sloshing and traveling with wheel creating out of balance situation?
G. Anderson
05-27-2007 18:31:07
 Re: 1949 M galloping at high speed in reply to leroy in ne, 05-27-2007 16:42:03
After three days on a tractor ride it was still doing it, so don't think the tires still had a flat spot. There is no fluid in the tires.
Brian in MO
05-27-2007 14:49:36
My first thought is the clamps that hold the rims to the wheels were not tightened equally causing the wheels to be off center. Brian
G. Anderson
05-27-2007 15:18:59
 Re: 1949 M galloping at high speed in reply to Brian in MO, 05-27-2007 14:49:36
That was my first thought. A tire shop adjusted the clamps and it still does it.
Bob Kerr
05-28-2007 14:08:56
 Re: 1949 M galloping at high speed in reply to G. Anderson, 05-27-2007 15:18:59
Mine does that also, I have one front rim that is a little bit tweaked but not too bad, but it does have water in the rears and that is what I was thinking caused mine to do it. I just drove mine 40 miles last monday to do some bushhogging so I had the mower on the back and it would hop fairly good, I just backed off the throttle and enjoyed the scenery. You might get someone to go along side on a bike or something and look close at the tires and wheels if you don't have water in the tires.
