Framall Final Exam Question
Tom Windsor
05-28-2007 18:09:42
third party image
A simple test queston:
What is it?
CGtractor
05-29-2007 06:27:50
 Re: Framall Final Exam Question in reply to Tom Windsor, 05-28-2007 18:09:42
It is an H with a M shifter grafted to it, possibly in the oil fill hole.
Tom Windsor
05-29-2007 09:50:34
 Re: HERE IS WHAT IT IS in reply to CGtractor, 05-29-2007 06:27:50
One of the regular contributors here, Ken Foxx, has done the engineering here. This tractor has the 9 speed transmission. As I understand it, as origionally set up, it was shifted with a cable arrangement. Ken made a mold of the mount on the left side--so the right is identical to the left. He then cast it around a fitting that screwed into the oil fill hole. He threw away all the cable arrangement and engineered it so that the right lever simply shifts backwards and forwards to shift into and out of the higher gears. It is a professional engineering job--and I suspect one of a kind. (Ken...if I have left something out or something is not correct, pleas fix it.)
Tom Windsor
little john
05-29-2007 10:45:14
 Re: HERE IS WHAT IT IS in reply to Tom Windsor, 05-29-2007 09:50:34
Congrats to Ken Foxx for an excellent piece of work! And thanks to you for sharing the picture and information.
Bob Kerr
05-29-2007 06:19:20
Is it a H cotton picker or is the second shifer a shuttle for an industrial tractor?
georgeky
05-28-2007 21:44:20
Alright Tom, What is it, I have never seen one like it. I have been waiting all night just to hear what it is.
the tractor vet
05-28-2007 20:11:58
Ok ya got me as in all my years around Farmalls i have never run across one before , SOOOOooooo o i graded and F for the day.
MN Scott
05-28-2007 19:19:05
Photoshopped? or someone is a good welder and has to much free time on his hands.
Tom Windsor
05-28-2007 20:11:56
 Re: Framall Final Exam Question in reply to MN Scott, 05-28-2007 19:19:05
No...not photo rigged.
D Slater
05-28-2007 19:17:42
Hard to tell for sure in picture but below shifter looks like its not cast and has been added for a conversation piece or riged up to shift a 9 speed.
Steven@AZ
05-28-2007 19:08:02
I was going to say an H until I saw the second shift lever... maybe it's a 5&4 like the trucks?
Nebraska Cowman
05-28-2007 18:42:47
 Re: Farmall Final Exam Question in reply to Tom Windsor, 05-28-2007 18:09:42
That's a special "road ranger" transmission for guy that have trouble getting in 2 gears at once. Cotton picker? Do both levers work? The standard "reverse operation" cover had the towers bolted on. Those aren't. So yeah Tom. What is it? Or were you referring to the hour meter?
JonMM
05-28-2007 18:29:32
My guess is a Super H with a M&W nine speed transmission
