parts source for 12v conversion
K.B.-826
05-29-2007 18:21:13
Finally got around to rewiring the old 240 this weekend. All set up for 12 volt neg with a Delco 10SI alternator. For the sake of keeping it somewhat original looking, I'd like to go with a internally resisted coil. Anyone know a source for a 12 volt internally resisted coil that has the same outside appearance? 240 should have the same coil as any smaller IH. I salvaged the alternator off of a 3010 Diesel. The pulley is too wide, as the belt just bottoms out in it. 240 has a 3/8" v-belt. Anyone know were to get a 3/8" v-belt pulley to fit a 10SI? Possibly an older GM car? Smaller the diameter the better.
hayfarmer
05-29-2007 18:45:22
 Re: parts source for 12v conversion in reply to K.B.-826, 05-29-2007 18:21:13
the 3010 Diesel was originally 24 volt, you sure your alternator is 12 volt?
K.B.-826
05-29-2007 19:02:53
 Re: parts source for 12v conversion in reply to hayfarmer, 05-29-2007 18:45:22
Yes, I'm sure. Originally the 3010, 4010, early 3020, and ealry 4020 diesels had a generator. Many have been converted to a straight 12 volt negitive ground system using a Delco 10SI alternator. I actually only purcahsed and resold the engine from that 3010, but obviously someone converted that tractor to 12V.
El Toro
05-29-2007 18:33:29
You can get one of those coils from Napa auto parts. The part number is 1C14SB and the cost is about $40.00. Don't know anything about the appearance. Hal
