brake/clutch shaft and pedal bushings
nspec
05-29-2007 18:26:50
Just took the pedals and the brake/clutch shaft out of my 53 super h. Sending the clutch pedal out for a bushing and plan on ordering a new shaft. The original was worn about 1/3 of the way through!!
Any tricks here? Seems pretty straightforward.
CNKS
05-29-2007 19:42:47
 Re: brake/clutch shaft and pedal bushings in reply to nspec, 05-29-2007 18:26:50
Any decent maching shop can put bushings in the pedals and make you a new shaft. Simpler for them than fixing your old one.
GordoSD
05-29-2007 18:49:33
I just did mine. Friend welded Brass/bronze on the shaft and I filed and sanded it down. 4 inch 40 grit flap wheel on the angle grinder, then b=====d file, then emery paper.Bw sure and pick up the correct thrust washers for assembly. They also work well to use for filing gauges.
Gordo
nspec
05-29-2007 19:09:34
 Re: brake/clutch shaft and pedal bushings in reply to GordoSD, 05-29-2007 18:49:33
Forgot to ask about the seals. How do I get them out, or do I really need to? How about new ones?
CNKS
05-29-2007 19:39:12
 Re: brake/clutch shaft and pedal bushings in reply to nspec, 05-29-2007 19:09:34
Replace them, any place that specializes in seals and bearings can cross the IH number to Chicago Rawhide or National, the two major seal suppliers. Or get them from Case-IH, price is usually higher for the exact same seal. Easy to get out without the shaft installed.
