Correct trans/diff oil for IH 3414 BL
markiz41
05-30-2007 15:41:25
Can anyone please tell me what the specs call for to use in this tractor? It has a manual 4-speed F/R shuttle trans with high/low range and a locking differential. Looks like one fill for all, am I right? The people at NAPA try to push gear oil on me, but it does not seem to be what I drained out of it.. Please help.
the tractor vet
05-30-2007 16:50:44
 Re: Correct trans/diff oil for IH 3414 BL in reply to markiz41, 05-30-2007 15:41:25
HyTran .
markiz41
05-30-2007 18:59:34
 Re: Correct trans/diff oil for IH 3414 BL in reply to the tractor vet, 05-30-2007 16:50:44
Thanks. This may sound ignorant but isn't HyTran hydraulic fluid? Or is it both? Sorry, I'm new to this.
georgeky
05-30-2007 19:15:57
 Re: Correct trans/diff oil for IH 3414 BL in reply to markiz41, 05-30-2007 18:59:34
The Tran part is for transmissions.
the tractor vet
05-30-2007 19:30:46
 Re: Correct trans/diff oil for IH 3414 BL in reply to georgeky, 05-30-2007 19:15:57
Hy Tran is a Hdy oil and also a transmisson oil and a torque convert oil . all in one .
markiz41
05-31-2007 05:03:40
 Great, thank you in reply to the tractor vet, 05-30-2007 19:30:46
I got you, thanks. I was under the impression that the torque converter was operated by the same fluid as the loader/backhoe hydraulic cylinders.. Or can you use HyTran in the L/B hydraulics as well? Is HyTran commonly available?
georgeky
05-31-2007 22:26:11
 Re: Great, thank you in reply to markiz41, 05-31-2007 05:03:40
Yes it works for everything. Hy-Tran is available at any CaseIH dealer. If there is not one close you can use equivalent oil from other companies. It will have a compatability chart on the buckets.
