gear noise or just norm ?
gm super a
05-30-2007 18:17:51
Hi all I replaced three bearings in my super a that I thought were the bad ones they were the spline shaft bearings the noise I had when I got the tractor was gone but I didnt get too drive on the road until sunday. In all gears it has gear noise. Is this normal? for HI A any thoughts would be helpful thanks
richwill
05-30-2007 21:29:18
 Re: gear noise or just norm ? in reply to gm super a, 05-30-2007 18:17:51
We found that adding a can of STP to our cub helped gear noiseafter just like you we still had noise after replacing 2 bearings
gene bender
05-30-2007 19:09:38
If you replaced the input bearing that was probably the main source of the noise as the gears are straight cut and known to not be quiet. Using 140wt in the tranny will also help. These were noisy when new.
