super axel for Surer C
vally farm
05-30-2007 20:30:14
Does anyone know of a wide front end that will fit easily under a Super C but be alot stronger? I am thinking of puting a loader on it for barn cleaning, manure pile handeling, etc. Love the size and the fit to my back end, but every thing I have read says the stock one won"t take much abuse. I live in NY, so there aren"t all those combine axles this way like some have out west more. Thanks, Mike
Hugh MacKay
05-31-2007 03:45:47
 Re: super axel for Surer C in reply to vally farm, 05-30-2007 20:30:14
Mike: I agree with Jim, the factory wide front will stand as much as the tractor. Most of these I've seen broke, it was front of engine block that broke. You can strengthen that by adding a flat plate between three bolt holes on clutch housing and bolt holes for cultivator mount an front bolster.
Janicholson
05-30-2007 21:37:51
No matter what axle you endup with, remember the tractor has no frame at the front. Just the engine block. They are broken at that point by hitting ditches and holes. A loader that has a frame system would be best, and no wide front is needed to make that work. Any loader that is appropriate will work very well with a narrow front. It will also be more menuverable. JimN
